Perspective Viewport issue
emastoyanov
emastoyanov
Hey, I have a problem with the perspective viewport. The whole screen is black, background and object, you cannot see anything unless you select the object, when you see the edges highlighted. Does anyone know how to fix this?
Kahylan
Hi!
Your perspective Viewport is using the Arnold Viewport. You can see that because the little "A"-Button on the top left has a border, which means it is active. If you click this A, it should switch to Viewport 2.0 like the other Viewports.
The Arnold Viewport does not recognise the Maya default light. So if you want to use the Arnold Viewport you need to create lights.
I hope it helps!
