Need Help: Arnold wont render Metalness
fwallaceX73ZS
fwallaceX73ZS
I tried out many different things, but my Arnold just wont render my Metallness and also my normal Map.
I never had this problem before, I plugged in every map as I usally do and tried every variation of it.
I even tried out just rendering a cube in a completely new scene and it still looks like plastik.
I put a picture from the Node Editor, thats how all my textures are plugged in. Switching Metalness on colourR doesnt work either.
Maybe there is a Problem in my Render Settings, but I cant find anything.
viewportviewportarnold renderarnold renderviewportviewportarnold renderarnold renderNode EditorNode EditorHow it looks in substance for refferenceHow it looks in substance for refference
Christoph_Schaedl
What kind of lights are in the scene? Without something to reflect metal looks flat.
https://linktr.ee/cg_oglu
fwallaceX73ZS
I used a Skydome light, I later tried an directional light, but it somehow only works on some part of the metall. Its really weird
Christoph_Schaedl
Use an hdri in your skydome. Metal needs something to reflect. If your skydome is blue all the metal does reflect is blue.
fwallaceX73ZS
It worked! Thank u really much 😄
