Ncloth and Mash Color node combined, Colors not showing up in Arnold Renderer
I am currently working on a University project where I use both the mash colour node, and ncloth on one object, but when I try to render it out using Arnold the colour comes out greyscale.
I've already tried:
- Making sure Color Vertex is selected in Mash_Repro.
- Making sure the Color node is enabled.
-  Toogle Display color Attribute.
- Assigning an Arnold Material.
- on the Mash_ReproMeshShape tab, mde sure Export Vertex color is selected under the Arnold options.
- Made sure the Color is the Arnold shader - aiUserDataColor, then set the Color Attr Name to colorSet.
- Also I've tried Adding the Color node before and after adding ncloth.
If anyone could please help me or give me some advice it would be much appreciated :).
(Btw if it's an obvious solution I just started my Digital Design Course at Uni, so I'm still getting my head around using the software.)
jordanjs
Hey there,
Did you ever find a solution to this problem? I'm having the same issue.
joostkonemann
The pitfall is that the actual shape being rendered is not the reproMesh, but a different one, normally named 'outputCloth'. Transfer the color sets from the reproMesh to the outputCloth mesh using 'Modeling menu set > Mesh > Transfer attributes' and the vertex colors should render properly (when you do the normal setup to render vertex colors with MASH in Arnold).
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
