Maya rendering with VRay gives white spots
Hello good people,
I am quite new to VRay. Maybe this is just a dump problem of me and could easily fixed with some adjustments in the render settings.
My scene is simple and it contains:
-A VRayDomelight with an outdoor HDRI
-A normal sphere with VRayMtl material
and using VRayBumpMtl(I did already try applying the bump map directly into my VRayMtl) to give my sphere a little bumps.
My sphere has a full Reflection color, and Reflection Glossiness.
And the problem happens when I map a normal texture file(black and white image) for my bumps into my VRayBumpMtl's "Map", and it is giving me white spots in my render.
The whitespot pixels have max color value.
I will provide as many images as I could, and I will really appreciate all of your help!
Thank you everyone!
damaggio
Hi, make sure you are clamping your HDR in Vray tap>Color Mappind Clamp level to default 20 ,check Clamp output, this should be on by default.
A personal suggestion, keep max subdivisions to 8 and up, not 4.
Your Blinn Fresnel 5.0 seems way high, leave at default 1.6...higher values are used for metallic shaders.
Those white spots are called fireflies and usually happens from very hot HDR maps, so they invented the clamping option.
Good luck.
Hi Damaggio,
Thank you for your time for helping me!
Unfortunately the fireflies are still there in my render even after  I enabled the "Clamp out" and set "Clamp Level to 20". I even tried changing the "Clamp level" to 1 and reduced the IOR to 1.6.
I appreciate your further help and anyone else who may have an idea.
Thank you everyone!
UPDATED:
FIXED thank you damaggio for leading me in the right direction!!
CHeers my friend!
damaggio
Was that the right thing then?
Just wanted other users to understand the solution, you were not very clear kvefpxo.
Thanks.
Hi damaggio,
So I followed your direction and was playing around in the color mapping section, then I enabled "subpixel mapping" and changed the Type to Exponential instead and it worked for me. Hope this will help others.
patrickY3GAB
Years later, this last bit has helped me today. Thank you all!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
