Maya render
jeffrey.reinoso
Maya render
jeffrey.reinoso
Hello, I’m animating a coin by using the keyframes in maya but then when I exported to premier pro the model is not moving or animated. Can someone help? I’m exporting as png.
cavescholar
So under RENDER SETTINGS window, COMMON Tab, from where it is set to PNG look down and find
' Frame/ Animation Ext: ' drop-down list.
Change to: name.#.ext , it will save as filename.01.png and so on.
Next, scroll down to the FRAME RANGE section and choose the range you need.
NOTE: Depending on how long your animation is, will determine the amount of time it takes to render, and the number of png's you get from the render.
Once you have them saved, you can import frames through Premiere Pros file menu.
You may want to have a separate folder they are saved in or copied to, because I believe Premiere has the option to import an entire folder as frames, which has all your images (animation).
(Render Settings screen cap below)
Good Luck!
Render Settings Window MayaRender Settings Window Maya
Type a product name
