Announcements
Maya and VRay Creating AOVs Collections
Hello community,
I am using VRay as my render, I am wondering how do you create AOVs collection for overriding in Maya 2017(also applies to 2018).
For example, when I don't want the "Diffuse pass" to be rendered in the car_layer, how do I create a "diffuse Collection" and disable it so it won't render in the car_layer but will render in the other layers. I have a workaround but its not efficient and causes problems.
And do you guys find the new render layer to be especially buggy? For example, sometimes my files's <layer name> will be incorrect(have other layer's name) and can only be corrected by shifting the layers around and re-rendering. And it would continuing rendering the passes you have already removed in your render setting.
Please be as detailed as possible in explaining your steps because the small steps are what I am need, as I have tried many things and didn't work.
Thank you all in advance for the help! I deeply appreciate it!
Replies (0)
