Maya 2020 Subscription License On Headless Linux host
jhickson70
jhickson70
I am testing Maya 2020 on our render farm.
I can only do silent installations which complete successfully.
Our licenses are subscription based.
Our render nodes are headless running CentOS with no user interface.
How do I license your product?
natasha.l
Hello @jhickson70
Thanks for reaching out on the forums. 😊
I will move this post to the Maya forum for you, as it is the appropriate place to get additional information on this subject.
Autodesk does not recommend conducting a hardware render (OGS) without a GPU as it requires GPU resources (frame buffers, vertex buffers, etc.) to render with, otherwise VP2 will just fail to initialize if it doesn't find a GPU. So you would need some type of display hardware that meets the system requirements.
Related Article: Maya 2017 render farm environment variables
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
jhickson70
Thanks for the response Natasha.
I should clarify that by headless I just mean the UI for CentOS is not installed, command line only.
We use Arnold for rendering on these nodes.
The question remains though: if our licenses are subscription based (SSO) how do I license Maya 2020 at the command line.
