I have a scene that I need to be able to render.
Its using the Render Setup system and has several layers. I can't render it anymore. I think this might have coincided with updating to maya 2017 update 3, but I cant be 100% sure, but it did used to work & I can't think what else changed.
Whenever I try to render the sequence ( Rendering>Render>Render Sequence ) I get the following error:
Starting Render Sequence with Arnold Renderer # Error: file: C:/Program Files/Autodesk/Maya2017/scripts/others/renderSequence.mel line 158: NameError: file <maya console> line 1: name 'rsm' is not defined # // Warning: file: C:/Program Files/Autodesk/Maya2017/scripts/others/renderSequence.mel line 160: Cannot render 'rs_UTIL' because we cannot switch to that layer. // # Error: file: C:/Program Files/Autodesk/Maya2017/scripts/others/renderSequence.mel line 158: NameError: file <maya console> line 1: name 'rsm' is not defined # // Warning: file: C:/Program Files/Autodesk/Maya2017/scripts/others/renderSequence.mel line 160: Cannot render 'rs_OOZE' because we cannot switch to that layer. // Sequence rendering completed
It says completed, but actually hasn't done anything.
Is there anything I can do to fix this - it kind of makes it impossible to render this sequence.
Thanks for any advice
