Maya 2016.5 Ex2 mental ray batch render is not outputing files
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I tried everything I can think of to make it work. I cleared preferences, exported my scene file to a new scene and rendered from there, etc. For some reason, Maya batch render will start and quickly ends with this line and shows no progress of rendering any images:
// Result: Rendering with mental ray... //
// Result: Rendering Completed. See mayaRenderLog.txt for information. //
I checked the project folder for my images but there none. I can still render a single frame from the Render View panel.
There's a solution I seen on other posts about this error but it seems to only work with 2017: http://forums.autodesk.com/t5/maya-shading-lighting-and/mental-ray-rendering-issue-maya-2016-5/m-p/6...
I also been using a workaround script that renders from the Render View panel, it's old and buggy but helps a bit with rendering: https://simplymaya.com/forum/showpost.php?p=323957&postcount=23
I included an attachment of a test scene. Even in a different scene I still get the error.
My computer specs:
Windows 7 Home Prem
Intel i5-3210m
Intel HD Graphics 4000
Maya Render Log (1/04/2017)
1/4/2017
Starting "C:\Program Files\Autodesk\Maya2016.5\bin\mayabatch.exe"
Initialized VP2.0 renderer {
Version : 2015.11.8.11. Feature Level 4.
Adapter : Intel(R) HD Graphics 4000
Vendor ID: 32902. Device ID : 358
Driver : ig7icd64.dll.dll:10.18.10.4425.
API : OpenGL V.3.3.
Max texture size : 16384 * 16384.
Max tex coords : 8
Shader versions supported (Vertex: 4, Geometry: 4, Pixel 4).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 1798.96 MB.
CPU Memory Limit: 3782.82 MB.
MultiDraw consolidation attempted to enable, but the graphics device does not support it. MultiDraw will be disabled.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 1.2 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
OpenCL evaluator choosing OpenCL platform Intel(R) Corporation.
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
mental ray for Maya 2016 Extension 2
mental ray: version 3.13.1.11, Jan 5 2016, revision 256946
mental ray: started on "Amari-PC", Wed Jan 04 13:34:03 2017
pymel.core : INFO : Updating pymel with pre-loaded plugins: invertShape, mayaHIK, GamePipeline, curveWarp, CloudImportExport, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, ATFPlugin, Mayatomr, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, VectorRender, gameFbxExporter, OpenEXRLoader, lookdevKit, Unfold3D, Type, mayaCharacterization, fbxmaya
Turtle Renderer 2017.0.0
Running Turtle startup script
+++++++ Turtle for Maya registered successfully ++++++
Warning: line 1: 'defaultColorMgtGlobals.cmEnabled' is already connected to 'mentalrayIblShape1.colorManagementEnabled'.
Warning: line 1: 'defaultColorMgtGlobals.configFileEnabled' is already connected to 'mentalrayIblShape1.colorManagementConfigFileEnabled'.
Warning: line 1: 'defaultColorMgtGlobals.configFilePath' is already connected to 'mentalrayIblShape1.colorManagementConfigFilePath'.
Warning: line 1: 'defaultColorMgtGlobals.workingSpaceName' is already connected to 'mentalrayIblShape1.workingSpace'.
File read in 7.2 seconds.
Error: line 1: KeyError: file C:\Program Files\Autodesk\Maya2016.5\bin\python27.zip\os.py line 432: MAYA_RENDER_SETUP_OVERRIDE_CONNECTABLE
Warning: line 1: Python callback failed
Result: C:/Users/Amari/Documents/Documents_and_Projects/Projects/Presentation_Prep/Presentation_Reel_setup_2015-2016/scenes/Presentation_Herbert_wireframe_004__10148.mb
Warning: int $interactive = 1; // for Flag -interactive
Warning: "C:\Users\Amari\AppData\Local\Temp\AST2FFD2372.tmp" line 9.21 : Redeclaration of variable "$interactive" shadows previous declaration at line 7. Previous value will be overwritten by explicit initializer.
Warning: file: C:/Program Files/Autodesk/Maya2016.5/scripts/others/mayaBatchRenderProcedure.mel line 604: Renderer returned an error while rendering 'defaultRenderLayer', please verify the output image.
Scene C:/Users/Amari/Documents/Documents_and_Projects/Projects/Presentation_Prep/Presentation_Reel_setup_2015-2016/scenes/Presentation_Herbert_wireframe_004__10148.mb completed.
