Announcements
Material with height map to unity
Hello! I want to export my model from Maya with textures. I have Albedo, MetallicSmoothnes, Roughness, Normal, AO and Height map, I'm using Stingray material because this material supports all the maps except Height map. I put the height map as displacement shader but doesn't work in Unity.
What material can I use for unity with all those maps? Can I use Stingray with Height map? Thanks.
Dark__Night
Did you ever find out a way to add a height map?
