Looking for a way to distort textures (or uv's) via noise map
I'm looking for a way to distort textures via noise map.
In unity there is a way to to have uv's become distorted by being fed a noise map.
Any similar means as long as the texture gets distorted via noise!
Thanks!
mspeer
Hi!
Just connect a noise texture to any of the Attributes of a place2dtexture or place3dtexture node.
Hi thanks for the suggestion but there is only 2 attributes which rotate uv and rotate frame which isn't working.
Am I missing something?
mspeer
Hi!
Rotate uses angles and accepts only one single value,
but there are many other Attributes for place2dTexture (Coverage,...
