Lighting
Lighting
Lighting
How do make a light see through of a Japanese paper window?
damaggio
What renderer aron?
It would be on mental say in maya 2016
damaggio
It would be better taking this time to change to another renderer, there's free version of renderman and also Arnold in 2017 , plus Vray and Redshift are very good options.
Mental ray is a very bad choice for your future in 3D.
mspeer
Hi!
This is very easy with Mental Ray, you have multiple options.
A) Select the mesh: RenderStats -> Casts Shadow ("disable").
B) In Material: Use Translucency (Transparency / Refraction has to be enabled and "Thin Walled" if you only use a one-sided surface for the window)
Choose the renderer that works best for you (Mental Ray has it's advantages and disadvantages as every renderer).
