04:29 PM
I have an animation and when I render it certain keyframed objects are not moved. Manually moving through the timeline works fine but when I hit render, some of these objects are not moved.
I've attached the scene below. View the scene from camera1 and scroll the timeline from frame 600 to 608. You can see the table move as the character bumps into it, but if you render these frames, only the character moves and not the table.
Scene:
https://drive.google.com/file/d/1fIEhdTsUscL6HhluJY5mA2Gu1AmWtz8O/view?usp=sharing
(Maya forums is removing it from the attachments for some reason.)
