Issue in creating shader network for substance shader in Maya hypershade
vinitlalan00
vinitlalan00
Community Visitor
Community Visitor
I imported a substance shader into Maya i.e. (.sbsar file) by downloading it from Substance Share and issue I am facing is that the same I imported into Hyper shade and to apply it to any object, I need to create a complete shader network.
Here when I clicked 'Create Shader Network', I am getting no commands and network is also not being created into hypershade.
I tried several times but it is not Working at all.
The error which I am getting in script editor is '// Error: line 1: Cannot find procedure "substanceNodeApplyWorkflow". // '
Can anyone know the solution for the same problem.?
nicolo_cadenelli
Community Visitor
Community Visitor
hey I have your same issue, did you manage to fix it?
Christoph_Schaedl
I can only guess.
Is the plugin loaded?
Are you using the latest version of the substance plugin?
https://linktr.ee/cg_oglu
