input from 2d texture is applying to surface shader but not to poly
yes_yeet_com
yes_yeet_com
In the hypershade the preview shows what is should look like, but on the cube has Blinn on it but is not applying the color to it. I've tried a lot of things, making the poly NURBs, tried only applying to a face. So, what I am I doing wrong? Thanks in advance!
Christoph_Schaedl
You are not in texture view mode. Try shortcut 6 on your keyboard.
https://linktr.ee/cg_oglu
