I want to apply mentalray shaders to nhair.
nagatasec
nagatasec
Versions of maya ...2018, OS...windows11
I am rendering using the mentalray environment for some reason, but I would like to apply mentalray shaders to the hair model created in nhair and output it.
Using functions such as converting nhair to polygons is not a problem as long as there is no difference in the rendering results.
I know this is a difficult question since the official support for this software has been discontinued for 6 years now, but I hope to get a good answer.
(I am using machine translation)
Christoph_Schaedl
I assume you have a reason to use Mental Ray but i fear the artists with the right knowledge are instinct.
Why not switch to Arnold?
https://linktr.ee/cg_oglu
nagatasec
Thanks for the reply.
I would love to, but there is a good reason I use mentalray.
I can't go into specifics, but I have a special shader plugin specifically for Mentalray that I have to use to do my job.
