How to put Arnold bloom effect only on select objects?
moshibadalov
moshibadalov
I am using the LensEffects imager in Arnold, which seems to add bloom to every object in the scene. I only want to add bloom to a few select objects. After hours of messing around with a test scene I was able to get one object to be unaffected by it (while 2 objects were affected), but it crashed soon after and I don't know what made it work. In this tutorial at the 1:30 mark and the 2:40 mark the instructor is able to change the bloom without affecting every object in the scene:
https://www.youtube.com/watch?v=UZVesY7A5bQ&t=14s
How is that done? I should add that my scene is lit with a simple skydome, with the sun turned off and the camera visibility set to zero to make the background black.
Stephen.Blair
Bloom is applied to pixels based on pixel intensity. It's not a per-object effect
// Stephen Blair
// Arnold Renderer Support
absoluteKelvin
would be nice to have a override on a set or something for certain objects only.
https://www.artstation.com/kelvintam
