How to combine textures?
I have a simple objects with different textures on each side. How can I combine all textures into 1 so that the object has only 1 texture onto it ?
Thanks.
Anifex09
Several ways to do this please send an visual example of your object or just send the scene file and I will apply some different textures to it for you to reference.
OK, here is a screen shot. I applied here simple lambert colors (in reality each color is a different file texture).
How to combine these in 1 uv
Thanks !
_sebastian_f
usually you would do a proper uv map, save a uv snapshot and place your images in photoshop based on the uv´s and load it back in maya as one file texture.
Clear, thanks. That what I was afraid of, because my real object has this shape but is smoothed, and therefore has a lot of small polygons which makes it unviewable in the exported file (because of the too narrow grid.
n8skow
Exporting your texture at a higher resolution should help with that...
