Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
How to blur darker pixels in a texture in Hypershade? (gradient blur) (arnold)
4 REPLIES 4
brandaosa
1855 Views, 4 Replies
I am creating a caustic texture (file sequence) which is masked by a smooth noise animation.
I want to apply a blur value to the caustic texture areas which are darker, in a gradient way.
I thought it was just a matter of connecting the noise texture to the Filter, Filter Offset, or Pre-Filter Radius of the caustic texture (a "file" node), but no.
Maybe creating some complicated expression to input on some arnold attribute?
How to output this effect?
4 REPLIES 4
mspeer
in reply to: brandaosa
Hi!
Sorry, there is no blur node available in Maya, so you can't do this.
Please add comments and vote here:
https://forums.autodesk.com/t5/maya-ideas/blur-node/idi-p/7957401
brandaosa
in reply to: mspeer
Thanks for the reply. Maya is older than my nephews and blur is a so common thing I can't even believe we are in 2019.
What about studing and building from scratch a shader using the GLSL shader? Any chance it could work with Arnold?
why one can't plug a bitmap to a pre-filter radius attr and just things would work?? I wonder...
mspeer
Hi!
No, no and no, this is not supported by Arnold.
brandaosa
in reply to: mspeer
Ok, so it is a pretty limited renderer in terms of customization.
Any possibility to retrieve UV coords from a bitmap using arnold?
Using maya software it looks like possible to create a simple pseudo shader like this:
    1.
$u = place2dTexture1.uCoord - .5;
$v = place2dTexture1.vCoord - .5;
$uv = <<$u,$v, 0>>;
$d = mag($uv);
$r = 0.3;
$c = smoothstep($r, $r+.02, $d);
$col =<<$c, $c, $c>>;
blinn1.colorR = $col.x;
blinn1.colorG = $col.y;
blinn1.colorB = $col.z;
Is it possible to get somehow uv coords using arnold?
Technology Administrators
