How to apply a normal map?
So what I've done is I've made a low poly version of my character and I have all the details of a high render version in a normal map and I'm just wondering how on earth do I apply the normal map to my character? I cant seem to find any simple tutorials explaining this easily and was just wondering if anyone could explain me the process I need to do?
halfstone
Assuming you are  using an aiStandard Shader -
  1. Create a Maya 2D File Texture node
  2. Create an Arnold aiNormalMap node
  3. Double-click on the Maya 2D File Texture node, and when it appears in the Attribute Editor, load your Normal Map in the "Image" slot.  In the Attribute Editor, find the "color space" setting and set that to "Raw".
  4. Connect the "output" of the Maya 2D File Texture Node to the "Input" of the AiNormalMap node.
  5. Connect the "Output" of the aiNormalMap node to the "Normal Camera" input of the aiStandardSurface shader.
That should do it.  A few notable details:
1.  The aiNormalMap node is set by default to read tangent-space normals, you shouldn't have to do anything with it.  It does have an "intensity' setting,  which allows you to fine-tune the effect of the map.  You should leave that alone until you need to fine-tune; you should be able to see the effect without touching that setting
2.  A normal map disturbs the way in which the camera interprets the surface direction, an illusion that is enhanced by light and shadow.  it's best if your shader has at least a small amount of specular reflection; this will enhance the effect of the normal map.
3.  Also note that normal mapping does not work with the Maya software renderer.  You should be using an Arnold material.  if you use a Maya Blinn or Phong material, you'll need to use a Maya "bump2d" node.  Connect it as you would any bump map, but set the "bump type" to "Tangent Space Normals".  You're much better off using the Arnold aiStandardSurface and aiNormalMap nodes described above.
hey sorry only seeing this now!
thank you so much for replying 😄
cyan_fire
how do you make a node?? how do you connect the input and output?
stephaniebellgardt
You can also just scroll down on the Arnold shader to the Geometry drop-down - then plug your file in the slot there. Make sure the map’s set to Raw, Tangent Space Normals, and you should be good to go 🙂
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
