how do i turn my tga files into a movie
I rendered my animation as a tga file I have about 4000 pictures I find them hard to load in how am I exactly supposed to string these together I saw one video suggesting playing them on f check then save it as a movie but f check only previews my files so I also tried going to render settings and compressing them wich said some crap then crashed help is appreciated
BenBisares
Autodesk Support
Autodesk Support
You could use FCheck to save your image sequence as a Quicktime movie on macOS. On Windows/Linux though you do not have that option.
That being said I wouldn't even use FCheck as it doesn't allow you to make any corrections or have many movie format options. The general industry workflow would be to import your image sequence into a video editing program like Adobe Premiere, do all your post work like colour correction etc., then save as a movie file.
Ben Bisares
thanks however if I was to go through all of my files in premiere pro I have about 4000+ so arranging would be a nightmare and I am on windows by the way i would hope that maya would have a handy way to do so
mspeer
Hi!
In short:
1. You need a video application which supports image sequences
2. You need to render the images with a sequence format that is supported by the application.
When importing in Premiere don't forget to set the checkmark for image sequence at Import window in Premiere.
Just search for:
premiere image sequence
You can find a lot Tutorials in the web.
For further help please show you sequence naming and maybe upload 3 images to test.
