Help.... UV Manipulator
i try to put the Cylindrical UV manipulator on the object... but it doesn't shows up.... anyone have answer??? in pic i already applied but nothing shows up
damaggio
Use automatic for now, will have the same result, can’t tell why is not showing from here .
// Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/others/performPolyForceUVArgList.mel line 873: polyProjection works only on polygonal faces; Try turning Polygons->ToolOptions->ConvertSelection On. //
i tried to use all the UVs but only the above warning show up..... do you know any solution???
damaggio
Start a new scene....Explain your process step by step plus pictures and use a polygon model and repeat the automatic mapping .
here i create new scene an make a simple polygon and try to apply a UV on the mesh... but this error comes out and UV not applied on the mesh.....
mspeer
Hi!
This works only with Polygon objects and not Nurbs or anything else.
Make sure to use Maya 2019.1 and
try a reset of your preferences.
Rename the folder prefs in folder 2019 to something like prefs_backup, or to reset everything, the folder 2019 to 2019_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
