GPU Rendering Error: insufficient device memory
Brandon_Curless
Brandon_Curless
Hi, I am trying to render Speedtree assets in Maya using Arnold with GPU enabled. I have a Quadro RTX 4000(8GB of GDDR6 VRAM) and am using a new HP Z Workstation with high specs. I am using most recent version of Maya and latest Quadro driver. I've tried multiple Speedtree assets also. Trying to render I get an error: Insufficient Device Memory. And then Maya crashes. Anyone know why the error occurs?  Pic ATTACHED. Thanks for any help.
I'm having the same problem, good luck getting a solution for that except a support ask you for logs and won't reply ever again.
