glslShader transparency bug
trubb1
trubb1
any ogsfx glslShader using the "transparency" technique annotation fails to depth sort objects correctly even when 100% opaque.
damaggio
Please Zip the scene here for Autodesk support.
trubb1
simple scene using the glslShader w/ AutodeskUberShader.ogsfx which uses the "transparency" annotation in it's technique. if you switch to "opaque" the shader will render fine.
with "transparency" annotation, depth peeling seems to be the only algorithm that will render correctly, but only if there is 100% on the shader opacity attr.
