Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
global illumination
13 REPLIES 13
Message 1 of 14
715 Views, 13 Replies
global illumination
would some one beable to write some instructions and how to illuminate a simple room with a large window using glabal illumation, I havent used mental ray much before and I dont know where to start.
thanks
Zoe
global illumination
thanks
Zoe
13 REPLIES 13
Message 2 of 14
Message 3 of 14
autodesk has a podcast of something similar using the mia_portal_light shader....in mental ray...and it is very easy.....
1. given an enclosed room with a window, place an area light covering your window.
1a. you can also setup an Environment >Physical Sun and Sky to light the exterior.
2. access the attribute editor for the area light and open the mental ray tab.
3. enable Use Light Shape and make sure Visible is on.
4. go down to Custom Shaders and click on the Light Shader map button on the far right.
5. select the Mia_portal_light on the mental ray tab>MentalRay Lights.
6. add the same shader created above to the Photon Emitter slot.
7. in the attribute editor for the portal light shader increase Intensity Multiplier to 100 or so.
it will get you moving in the right direction....you did say you were new to mr didn't you?
Message 4 of 14
Thanks alot I'll give that a try, yes I am, I've never had much opportunity to use it and theres not much free tutorials etc on the internet, would you recommend any books or anything?
Zoe
Zoe
Message 5 of 14
I have done as you said and have made the area light and accessed its attributes (as you can see). I have included an image of the mental ray tab, which of these settings am I supposed to use? Also is the environment menu at the top and which set will I find it under (i.e. animation, rendering) as I cant see it.
Thank you!!
Zoe
414_AtAXcDjTxBpnbIUDD16b.psd
Thank you!!
Zoe
Message 6 of 14
I am on version 2008....
Message 7 of 14
I've got 7 so I assume thats why I dont have the same settings, is there a way to achieve this in 7??? I dont have the mr light option either.
thank you!!
Zoe
thank you!!
Zoe
Message 8 of 14
Message 9 of 14
I have a quick question on the Portal Light. If I turn Visibility on the portal light blocks the view outside the window from in the room. I understand that turning visibility on 'blocks' Final Gather from having to perform unnecessary calculations but how do you still achieve this without obscuring the vew outside.
Hope that makes sense
Message 10 of 14
........it's just the way the podcast showed it.....so do what works for your scene....
Message 11 of 14
Where do I find the podcast?
Zoee
Zoee
Message 12 of 14
http://www.alias.com/glb/eng/support/maya/podcasts/index.jsp
at the subscription center....
but I think you have to be a subscriber to one of the memberships like gold or platimum....not sure, exactly......they have an archive of past ones....and a new one weekly.
Message 13 of 14
thank you!!
Zoe
Hello
In 7 you can use a point light and convert to a mental ray area light with a square projection.
To simulate the light coming from the sky, plug a mib_cie_d shader to the light color.
thank you!!
Zoe
Hello
Message 14 of 14
dangerweenie
dangerweenie
Do you know how to hook up geometry to the area light after setting the Light Shape to "User"?
I tried the nurbsSurfaceShape.message to areaLight1.object .... doesn't seem to work.
Any help is much appreciated.
Thanks.
Thanks.
