Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Geometry is not receiving shadows
3 REPLIES 3
EderSouzadesigner
2581 Views, 3 Replies
Hi there
I am having a issue with a geometry that doesn't receive shadows. I have double checked all the settings for the mesh and all of them are checked just such as the rest of the scene. I will be attaching a render so you can see the problem. I am rendering in Mental ray and materials are all Blinn and Lambert for indirect lighting I am using an IBL and a directional light.
3 REPLIES 3
So all meshes have cast shadows enabled....?
the shadows seem quite bright for an IBL ... Are you using only one light source?
Hi Damaggio
I found the issue thanks god... Lol So it was the vertices twisted!
Once I "set normal to face" the mesh flipped the normal to wrong way and I had to flipped back to right position and that is it. The shadows were there 🙂
Thank you very much for you reply!
Cool great...if you set your viewport to show reversed normals it will help you a lot...In the Panels menu set Lighting> Two sided lighting, leave unchecked.
