Error with render settings - values are incorrect?
xhaviergrzn4
Observer Observer
xhaviergrzn4
Observer
Observer
My values are being input incorrectly in render settings. My pixel aspect ratio is set at 1000.00 and I can't change it to be a lower value. I type 1 in the box and it changes to 1000.00. I type 2 and it changes to 2000.00. All my values are elevated like that. I have the same problem in resolution. I type 300 in resolution and it rises to "300000.00".
When I try to edit image size, the render displays nothing. I can't make a custom size, only use the presets. I try to render something in 3508x2480, but the render only displays a singular horizontal line.
Another weird thing that happens is that editing the width edits the height? no matter what I put in width, it changes the height of the render. Something is seriously wrong with my Maya.
stevenjamestaylor
try going into your Maya folder and deleting the prefs files - sometimes they get wacky and will rebuild when you reOpen Maya-
what happens when you use a preset? does it give you correct values?
