Error on adding Albedo_var and others to passes
04:12 AM
I'm using Maya 2017.
I open render settings -> Passes. I then click on the cog next to output, create output -> custom. I name it and then right click to add albedo and albedo_var. When I am done and click create it outputs:
// Error: file: /opt/pixar/RenderManForMaya-21.4-maya2017/scripts/renderManNodes.mel line 1399: rmanSetupAOV: NO TYPE FOUND ! -> mode = 'albedo_var' (Please report on the forum)
It does this with out channels to such as diffuse and diffuse_mse. Any have any ideas on what I might be doing wrong? Also, I've never had an error tell me to report on a forum before, makes a lot of sense.
Chris
Link copied
