error: no renderable object is selected for assignment
i created a shrub using content browser,  converted into polygon, created  an aistandardsurface for texture in hypershade. but the problem is when i right click to assign texture,  it throws this error......please help🥺🙏
hamsterHamster
Isn't that you need to select the object and then RMB>AssignMaterialToSelection without selecting the material swatch? Alternatively, you can MMB-drag-drop on the object in 3D viewport. Selecting the object and RMB>AssignExistingMaterial>.. also will do.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
