Error: [gpu] unable to initialize NVIDIA NVML (GPU-rendering)
I have the most up to date graphic driver 456.71. I have a gtx 1060. When i try to run ipr in render view I get this error code Error: [gpu] unable to initialize NVIDIA NVML (GPU-rendering). I have tried reinstalling my drivers I have no idea why it isn't working. Please help
Christoph_Schaedl
Please post a debug log.
Set the verbosity level to debug or info.
https://docs.arnoldrenderer.com/display/A5AFMUG/Log
https://linktr.ee/cg_oglu
Stephen.Blair
Also, can you please run "C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe" ? what is printed out
// Stephen Blair
// Arnold Renderer Support
i could not run the nvml-smi exe. But i fixed the error by replacing the nvml.dll (2017) file in the C:\Program Files\NVIDIA Corporation\NVSMI with  the C:\Windows\System32 nvml.dll (2020) file. And now i can render with my gpu. thank you for the help guys
Not an AutoDesk user, but was using a software library called py3nvml (for accessing GPU stats using a programming language called python) and I did the same thing.
It worked!
