Announcements
defaultArnoldDriver / aiAOVDriver access in Maya 2022 Batch Mode
luis.armengolHXNHW
Observer Observer
luis.armengolHXNHW
Observer
Observer
In Maya 2022 Batch mode there is not access to any output driver of Arnold, giving errors if you try to query or setting some output attributes like the file format.
cmds.setAttr("defaultArnoldDriver.aiTranslator", "tif", type="string")
RuntimeError: setAttr: No object matches name: defaultArnoldDriver.aiTranslator
Also, if you try to export the scene from batch mode using arnoldExportAss() command therre are some warnings from Arnold/MtoA that points also to the output drivers.
00:00:01 701MB WARNING | [mtoa] Output driver 0 for AOV "RGBA" is null
and the ASS files exported dont have options.outputs attributed established.
This is the options of a batch mode exported ASS
options
 AA_samples 4
 AA_seed 101
 xres 1000
 yres 1000
 texture_per_file_stats on
 texture_searchpath "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
 texture_automip off
 camera "RefImageCameraShape"
 color_manager "defaultColorMgtGlobals"
 frame 101
 fps 25
 procedural_searchpath "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
 GI_diffuse_depth 2
 GI_specular_depth 1
 GI_transmission_depth 6
 GI_diffuse_samples 4
 GI_sss_samples 5
 declare render_layer constant STRING
 render_layer "defaultRenderLayer"
And this is the exported ASS of the same scene in GUI mode
options
 AA_samples 4
 outputs "RGBA RGBA defaultArnoldFilter/gaussian_filter defaultArnoldDriver/driver_tiff.RGBA"
 AA_seed 101
 xres 1000
 yres 1000
 texture_searchpath "xxxxxxxxxxxxxxxxxxxx"
 texture_automip off
 frame 101
 fps 25
 procedural_searchpath "xxxxxxxxxxxxx"
 GI_diffuse_depth 2
 GI_specular_depth 1
 GI_sss_samples 5
Any clue??
luis.armengolXLAVP
Its working again calling the following code from the batch command. I am already calling this code on NewSceneOpened and SceneOpened scriptjobs everytime but I dont know why that call was working fine in Maya 2016 but not in Maya 2022.
import mtoa.core as core
core.createOptions()
