deep exr arnold render using batch render GPU
consrojo
consrojo
Im trying to render a RGBA deep exr using arnold, the first try it finished the task, getting this message int the script editor:
// Percentage of rendering done: 100 (C:/Users/ipco/Documents/maya/projects/orc22/images/pasto_arboles041024/041024RGBAdeeprender_004.exr)
Rendering Completed. See mayaRenderLog.txt for information.
when i was trying to check the rendered files, i could not find them.
the second try i used the render sequence option but the script editor message was:
// Warning: WARNING | [gpu] raw drivers ("defaultArnoldDriver/driver_deepexr.RGBA") not supported on the GPU
this is the settings that im using to render those deep exr files.
Is there a way to render deep exr using GPU?
Tks in advance.
Stephen.Blair
The deep exr driver is not suppoted on GPU yet.
Help | Supported Features and Known Limitations | Autodesk
// Stephen Blair
// Arnold Renderer Support
consrojo
Tks for the answer, how can i get that deep exr, using CPU?
if you know can you point to where i could learn something bout.
Tks in advance again.
