Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Cell shading issue...
11 REPLIES 11
Message 1 of 12
1222 Views, 11 Replies
I've created a Shaded Brightness three Tone and applied to a surface in a scene with 4 different directional lights but when I make a Render it the shadows looks terrible. I need to know what can I do to fix this. I've attached an image with a render showing the problem.
11 REPLIES 11
Message 2 of 12
n8skow
The sphere looks kinda blocky - have you tried increasing the tesselation?
Also try softening your normals.
Message 3 of 12
in reply to: n8skow
Sorry for the delay, I've tried to increase the tesselation but doesn't work.
About the softening, how do you soften the normals of a NURB Sphere?
Thanks for your answer
Message 4 of 12
n8skow
Can you upload your scene file?
Message 5 of 12
in reply to: n8skow
Message 6 of 12
n8skow
Is this a Maya 2015 scene?
Can you save out a .ma file - (Maya 2014 here...)
Message 7 of 12
in reply to: n8skow
it's a Maya 2014 scene.
And won't let me save it as .ma, when i try to save displays this messaje: "file contains unknown nodes or data. To preserve this information, the current file type cannot be changed."
Message 8 of 12
n8skow
Hmmm, I'm getting an error message when I open the file in 2014 here:
requires "cartoonShader60" "6.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "cartoonShader60", was not found on MAYA_PLUG_IN_PATH. #
// Warning: line 0: Unrecognized node type for node 'cartoonRenderGlobals1'; preserving node information during this session. //
// Warning: line 0: Unrecognized node type for node 'tierra_cartoonRenderGlobals1'; preserving node information during this session. //
// Warning: line 0: Unrecognized node type for node 'techos_cartoonRenderGlobals1'; preserving node information during this session. //
// File read in 1 seconds.
// Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
Is cartoonShader a 3rd party plug-in you installed?
Also - when I look in the hypershade, I'm not seeing a toon material - how did you go about creating the material you are using?
Message 9 of 12
in reply to: n8skow
That's weird, I've used the Shaded Brightness three tone in the Toon menu.
I've cleaned some settings in the file, try to download it again please.
https://drive.google.com/file/d/0BxmEkjoXt3wuYVRlNlgzdlM4LTg/edit?usp=sharing
Message 10 of 12
n8skow
Still no luck... when I open your file and look at the hypershade - there is no toon shader.
I've just created a new shaded brightness 3 tone material and assigned it to the sphere...
One thing I"m noticing though is you have a directional light with depth map shadows turned on - that may actually be what's causing that rough terminator in your render. You sould be able to tweak the resolution and filter size to lessen the issue you are seeing -or- possibly used ray traced shadows instead.
Message 11 of 12
in reply to: n8skow
Thanks!!! that worked perfectly!
Message 12 of 12
n8skow
Glad to hear.
Smiley Happy
