Can not assign materials
I'm having this problem where I have an object with a lambert on it but it seems that this same lambert gets applied to everything I create. Like, this one object has a red lambert then when I create a sphere or cube it comes out with this same red lambert. I tried assigning a new material but it isn't appied to the object. It also when I change the material attributes for this red lambert every other object changes with it. Can anyone tell me what's going on? It will be very appreciated!
damaggio
Lambert 1 is the default material in Maya...for any new scene, it's a good habit to change to a new shader as you continue modeling...now you should be able to easily apply any material you want to any object in the scene...let us know if the problem continues.
I'm sorry for the late reply and yes this did work. Thank you very much for
helping me.
*Kimberly Gholston*
damaggio
Great gholstonka...good luck.
