Batch render // Error: V-Ray : There was a fatal error building the scene for V-
Message 1 of 16
Everything renders well, but then once I insert this one rigged  model, it gives me an // Error: V-Ray : There was a fatal error building the scene for V-Ray. I need to fix this asap because the project deadline is Monday.
Replies (15)
Message 2 of 16
mspeer
Hi!
With this amount of information, i can only say there is an error and it's related to V-Ray.
Look at the mayaRenderLog.txt for more information.
Message 3 of 16
Okay
Message 4 of 16
Where can I find it? I went to Users/Documents/Maya and clicked mayalog but nothing inside. Unless that's not it?
Message 5 of 16
Someone please help me.
Message 6 of 16
mspeer
Hi!
It should be besides the mayalog.
Please try any other renderer and scene with batch render to make sure the mayaRenderLog.txt will be created.
Message 7 of 16
Starting "C:\Program Files\Autodesk\Maya2017\bin\mayabatch.exe"
Initialized VP2.0 renderer {
Version : 2016.3.18.11. Feature Level 5.
Adapter : GeForce 940MX/PCIe/SSE2
Vendor ID: 4318. Device ID : 22806
Driver : .
API : OpenGL V.4.5.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 2048 MB.
CPU Memory Limit: 7625.3 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Unable to detect NVidia driver version. Disabling asynchronous read-back for OpenCL.
Detected 3 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.1 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_fp64 cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 8.0.0.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
2: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.1 .
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
mental ray for Maya 2017
mental ray: Found 1 GPU with vendor's API.
mental ray: Found 1 CUDA device.
mental ray: version 3.14.3.41, 25 Feb 2017, revision 287619
mental ray: started on "DESKTOP-13KS7LI", Sun Jul 23 19:38:53 2017
mental ray: Identified file "architectural.so" as identical to "architectural.dll"
mental ray: Identified file "paint.so" as identical to "paint.dll"
mental ray: Identified file "subsurface.so" as identical to "subsurface.dll"
mental ray: Identified file "layering.so" as identical to "layering.dll"
[2017/Jul/23|19:38:56] V-Ray: V-Ray for Maya version 3.52.03 from Jun 14 2017, 22:33:36
[2017/Jul/23|19:38:56] V-Ray: V-Ray core version is 3.52.03
[2017/Jul/23|19:38:57] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2017\vray/vrayplugins/vray_*.dll"
[2017/Jul/23|19:38:58] V-Ray: 75 plugin(s) loaded successfully
[2017/Jul/23|19:38:58] V-Ray: Finished loading plugins.
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node vrayMultiProjection (id: 1115335/0x001104C7)
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node VRayCurvature (id: 1115347/0x001104D3)
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node VRayTriplanar (id: 1115362/0x001104E2)
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node VRaySkinMtl (id: 1115348/0x001104D4)
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node VRayPointParticleMtl (id: 1115353/0x001104D9)
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node VRayStochasticFlakesMtl (id: 1115359/0x001104DF)
[2017/Jul/23|19:39:00] V-Ray: Registered dynamic node VRayAlSurface (id: 1115350/0x001104D6)
pymel.core : INFO : Updating pymel with pre-loaded plugins: mayaHIK, invertShape, GamePipeline, CloudImportExport, curveWarp, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, hairPhysicalShader, ATFPlugin, Mayatomr, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, vrayformaya, VectorRender, gameFbxExporter, OpenEXRLoader, lookdevKit, Unfold3D, mayaCharacterization, mtoa, renderSetup, fbxmaya
Maya 2017 importing module pymel 1.0.9 (C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\__init__.py)
Error: file: C:/ProgramData/Autodesk/ApplicationPlugins/MayaBonusTools-2014-2017/Contents/scripts-2017/bonusToolsMenu.mel line 1670: UI commands can't be run in batch mode.
File read in 0.86 seconds.
Result: C:/Users/carol/Documents/maya/projects/default/scenes/untitled__7884.mb
Warning: int $interactive = 1; // for Flag -interactive
Warning: "C:\Users\carol\AppData\Local\Temp\ASTAE6411992.tmp" line 9.21 : Redeclaration of variable "$interactive" shadows previous declaration at line 7. Previous value will be overwritten by explicit initializer.
V-Ray: Starting render
[2017/Jul/23|19:39:11] V-Ray: Exporting scene to V-Ray.
[2017/Jul/23|19:39:11] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2017/Jul/23|19:39:11] V-Ray: Translating scene geometry for V-Ray
[2017/Jul/23|19:39:11] V-Ray error: There was a fatal error building the scene for V-Ray.
[2017/Jul/23|19:39:11] V-Ray: Render complete
[2017/Jul/23|19:39:11] V-Ray: ========================
[2017/Jul/23|19:39:11] V-Ray: Clearing exporter memory...
[2017/Jul/23|19:39:11] V-Ray: Total time clearing exporter memory 0h 0m 0.0s (0.0 s)
Scene C:/Users/carol/Documents/maya/projects/default/scenes/untitled__7884.mb completed.
Message 8 of 16
I can render just fine with any other model, but soon as I use this one model it wont render. once I do render view.
Message 9 of 16
Please help me 😞
Message 10 of 16
mspeer
Hi!
There seems to be a problem with your geometry (mesh) or with something that comes directly after "Translating scene geometry for V-Ray" (check other ...log.txt for a render that worked)
Message 11 of 16
How do I do that?
Message 12 of 16
Driver : .
API : OpenGL V.4.5.
Max tex coords : 32
Message 13 of 16
Thats part 1, part 2 below
Message 14 of 16
its too large, it will not allow me
Message 15 of 16
This happens for creating invalid connection between v-ray and non-vray nodes together, if there is any texture created with PSD Network from UV Editor, and then both 'color' (non v-ray node) and 'diffuse' (v-ray node) are loaded together in the photoshop file, this is a classic glitch and can be avoided by not using psd network for any uv based texturing, you can use the psd file to set up texture co ordinates but make sure to save as a JPG file to load for that vray material color slot, avoid loading any psd file to model sets.
Additionally, ensure to write nCache data along with removing nucleus if there is any fx added to the scene, can solve it in a jiffy.
Hope this helped.
Cheers!
S.
Message 16 of 16
llstar
In my case, when I insert the image that named other language besides English for 'reflection' in v-ray.
that error sentence came out.
1. check the image name or folder's name (Don't use other language without English)
2. Make sure you set 'Set Project ' and create folder for your works.
I hope it works. Smiley Very Happy
