Bake a texture sequence in Maya 2018
Hi, I'm trying to bake a file texture that combines some a projection node with some other colour correction nodes into a new texture.  I know you can use convert to file texture in the hypershade to bake a single frame, but is there a way to bake a texture sequence from 1-100?
There are a couple of old script lying around that work with older versions of maya but is there anything available for maya 2018?
thanks
Figured it out!
Using  Kiel Knebba's python script and following this thread https://forums.autodesk.com/t5/maya-shading-lighting-and/baking-mental-ray-s-ao-as-texture-for-all-f... I was able to get the script working.
import maya.cmds as cmds
scriptName = 'bakeTextureSequence'
scriptsDir = cmds.internalVar(userScriptDir=True)
execfile(scriptsDir + scriptName + '.py')
bakeTextureSequence()
Unfortunately, there was a transparency map in the node network, that was not being taken into account.
if you change line 530 in the bakeTextureSequence.py alpha from 0 to 1 you can use transparency maps.
              file = cmds.convertSolidTx(shader, eachGeo, antiAlias=0, bm=1, fts=1, sp=0, sh=0, alpha=1, doubleSided=0, componentRange=0, resolutionX=xRes, resolutionY=xRes, fileFormat=fileFormat, fileImageName=imageDir)
