backburner error timeout executing command
patriot6991
Message 1 of 1
patriot6991
Hi everyone.
I have problems with errors in specific scenes.
After several minutes of sending the render job to backburner, I get an error and can not render.
My work machine and backburner log, backburnerServer log are the following.
OS:Windows10
Tool:Maya2017 update5, backburner2019
Renderer:MtoA 3.0.0.2
CPU:Xeon W3680 3.33GHz 12CPUs
RAM:12GB
----backburner.log----
WRN Task error from rs03
ERR Job 'cut02_test' (#$$??$$##) failed for rs03
ERR Error message: Launcher: Timed out executing command:"C:\Program Files (x86)\Autodesk\Backburner\Adapters\CmdjobAdapter.exe" "-o" "PingTask" "-l" "Info" "-j" "C:\Users\RS03\AppData\Local\backburner\ServerJob\cut02_test.xml.details" "-e" "159085
----backburnerServer.log----
INF Receiving new job from 172.29.49.250
INF Job 'cut02_test' received and ready
INF Launching 'Command Line Tool'
INF New task assigned: 3
INF [ServerMessage]ProcessStarted processId=5752
ERR Task error: Launcher: Timed out executing command:"C:\Program Files (x86)\Autodesk\Backburner\Adapters\CmdjobAdapter.exe" "-o" "PingTask" "-l" "Info" "-j" "C:\Users\RS03\AppData\Local\backburner\ServerJob\cut02_test.xml.details" "-e" "159085" "-s" "3" "-n" "1" C:\Users\RS03\AppData\Local\Temp\adp1027: No such file or directory
ERR Launcher: Timed out executing command:"C:\Program Files (x86)\Autodesk\Backburner\Adapters\CmdjobAdapter.exe" "-o" "PingTask" "-l" "Info" "-j" "C:\Users\RS03\AppData\Local\backburner\ServerJob\cut02_test.xml.details" "-e" "159085" "-s" "3" "-n" "1" C:\Users\RS03\AppData\Local\Temp\adp1027: No such file or directory
INF Application is down
I have been rendering with backburner without problems so far.
Even a relatively heavy scene took time but it was successful.
I sent a job and monitored the rendering machine, but it looks like an error occurred before rendering started.
He has similar problems with me, but he uses 3dsmax.
Backburner 2015 Launcher: Timed out executing command
In this thread there are ’Wait for MAX to Load' setting items like images, but not in maya.
I think that this item is due to an error before the rendering starts, but I do not know how to solve with maya.
I read the backburner user guide and found the setting item 'acknowledgment timeout', but it did not work.
Another thing that can be considered is that the scene is too heavy and the machine power is not enough.
Even trivial things are waiting for comments.
Nikita
Replies (0)
