arnoldrenderview decelerates
carlcox62
carlcox62
an issue with the arnoldrenderview every time i open it. even its not rendering my sytem calculates and it is almost impossible to  even change slightly in the viewport. this was not from beginning, i was able to do 3d manipulation earlier. i tried deleting prefs.. further my render settings are very low. far below default, i set all to 0. saved ui threads are 3, the resolution is hd540 with a testres. of 25%! i cant do nothing, it renders too long even if not.
my spec.: 16gbytes ddr4@1600mhz,
3060rtx 6gbytes laptop gpu,
intel core i5 4x2,5ghz 8threads,
ssd 500 gbytes with 180gbyte free space
hamsterHamster
I guess, it is greatly dependent on what you are rendering, how stuffed is the frame, how complex are shaders. Test on a simpler scene, with one light and pCube. If the problem persist, post some lightweight zipped MA with that problematic scene setup.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
carlcox62
it is definetly not the scene, there is only one primitive not smoothed and some point lights. i test it every time like this, after changing and hope it gets faster. i reinstalled maya and did some cleanup in the registry, deleted unnecessary temporary files .... i also deleted every autodesk folder i could find on my hard drive. the renderview's, apart from performance for 3d manipulation or updating the scene, also its behavior if its not live do not affect the overall performance anymore.
