The error has popped up
Error: line 1: MelError: file C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\core\language.py line 992: Error during execution of MEL script: line 1: AttributeError: file C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\core\nodetypes.py line 409: nt.Unknown(u'defaultArnoldRenderOptions') has no attribute or method named 'drivers'
Script:
it worked in the beginning and now it wont load and the plug in is checked it also says
createArnoldRendererCommonGlobalsTab
what does this mean, and how can i fix my problem, because i really need Arnold as soon as possible.
Hi
That's a scene-specific problem with some nodes.
Do you have these four nodes in the scene?
- defaultArnoldRenderOptions
- defaultArnoldDriver
- defaultArnoldFilter
- defaultArnoldDisplayDriver
You can check in the Outliner, just clear Display > DAG Objects Only
If so, then try this:
- close the Render Settings dialog
- delete those four nodes
- save the scene (with a new name)
- restart Maya
- load the scene you just saved
Thank you! That's the first solution that I've tried after many that works. Next beer's on me 😉
