Announcements
Arnold Rendering Error: Nans or Infs
songiesworld
Message 1 of 10
songiesworld
I am using Maya 2019 and one of the objs is not rendering in Arnold Renderer.  It renders in other ones, but not that one.  This error Message keeps coming up:  // Warning: resetting parameter nlist on /Landing_Pod/Pod/Body/Frame/FrameShape (found: nans or infs)
Is there a solution for figuring out how to get rid of the Nans or Infs.  I did a cleanup of the mesh, looked into the texture and changed it, deleted the mesh and brought it back, and I am still running into a error.
Thank you!
Replies (9)
Message 2 of 10
hamsterHamster
Try saving MA, then edit the file - replace NaN with 0.0.
I never stumbled upon the Infs, see the context - share back what those were.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Message 3 of 10
songiesworld
Thank you for the quick response!,
"replace NaN with 0.0." When you say that, how would I replace NaN with 0.0?
Thanks!
Message 4 of 10
Stephen.Blair
It's a problem with the normals (nlist = normals list).
So take a look at the normals in Maya. Maybe use the utility shader to visualize the normals...
// Stephen Blair
// Arnold Renderer Support
Message 5 of 10
songiesworld
@Stephen.Blair
Thank you for your response!
I've looked into the normals to see if there were any issues with it but it's still not rendering.  Is there a more specific way you would suggest?  This is the mesh that I am working with.
Message 6 of 10
mspeer
Hi!
Please provide a scene-file with that object.
If this is an imported object from any 3rd party file format, please provide that file as well.
Message 7 of 10
songiesworld
@mspeer
Here it is!
Message 8 of 10
mspeer
Hi!
I wonder how you could open the scene, here it did not work because of massive error messages.
Recovered scene attached.
Message 9 of 10
mspeer
Hi!
Please also check the inner part of the "Frame" object, it seems there are some unneeded faces that need to be deleted.
Message 10 of 10
songiesworld
@mspeer
Ah ok! Thank you! This was actually a model that was sent to me, so I've been trying to figure out the errors.
