Announcements
3D ramp node (or something that would create a similar effect)?
user20202022
user20202022
Is there a way to create a 3d ramp node within Maya (or something that achieves the same effect)?
I'm working on a visual development model and I'm basically trying to cheat in an ao layer for visualization purposes within the viewport (you'll see below why turning on AO doesn't solve my problem).
The asset is a layer of rocks on top of a light source (so basically, light shines through the cracks). If this were a final asset, I might try using an AO map and linking it to the translucence node or something like that, but since it's just a visual development model there are no final UVs or even final rock placement yet. We're just trying to sell the look of picture and want to be able to visualize how this asset will look as we tumble around the scene with the director.
My thought process is, that if I can create a 3d ramp node (and just map white at the bottom of the ramp and the rock color at the top of the ramp), as I move the rocks up they'll turn gray and as I move the rocks down (closer to where the light source is) they'll turn white (thereby mimicking the light shining through).
The reason I don't want to throw on some UVs and bake out an AO map, is because the model is very much still in progress. So as we move rocks around within the pile, the ao map would become inaccurate and the light would be shining through in areas we don't want.
Sorry, I wish I could share pictures so that I could explain it more clearly, but obviously I can't for confidentiality purposes haha
Any help or ideas would be much appreciated. Thanks!
hamsterHamster
You can create any 2D texture as a Projection. Hypershade>Create>2D_Textures>2D_Projection (which is misleading, it is 3D). Now any 2D texture you create will have own 3D placement node which you can transform as needed. After you are done, don't forget to switch back to 2D Normal.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
user20202022
Awesome, worked perfectly. Thanks so much!
