Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
2D motion vector and image cards with alpha
4 REPLIES 4
dkrelina
508 Views, 4 Replies
I'm using Maya 2015 and metal ray. I'm rendering an image sequence with a 2D Motion Vector pass (mv2DToxik). I'm noticing that the MV pass is not getting the transparency information from the image cards in the scene. How do I render an MV pass that respects the transparency of my shaders?
motion_vector_alpha_blur_note.0180.jpgmotion_vector_alpha_grey.0180.jpgmotion_vector_alpha_mv.0180.jpgmotion_vector_alpha_rgb.0180.jpgmotion_vector_alpha_blur.0180.jpg
4 REPLIES 4
mspeer
in reply to: dkrelina
Hi!
You can't render "transparent motion". A Pixel can store information for one direction or the other, but not both (it's the same problem as with Z-Depth). You can however use multiple layers with different masks and/or moving objects (motion vectors) and composite them later.
dkrelina
in reply to: mspeer
Ah, I see. That makes sense. So then the solution would be to have multiple MV passes and matte passes and then combine them together to create a "master MV pass" in comp. Correct?
So here is the problem... How do I create the matte passes for the objects with transparent shaders? I am trying to render a puzzle matte in metal ray using the Custom Color pass combined with writeToColorBuffer and I'm still getting the same issue. No transparency.
Is it possible to render a matte pass with transparency using a pass? Or can this only be done with a layer?
If with a layer, do I need to create an entirely new set of shaders, and then re-assign one by one? Or is it possible to maintain the transparency with an override?
What's the best way to create the matte pass with transparency?
mspeer
Hi!
"So then the solution would be to have multiple MV passes and matte passes and then combine them together to create a "master MV pass" in comp."
No, at the moment you combine them you still only get one direction.
Think about 2 semi transparent objects, one moves to the left and an other behind moves to the right.
So you need to render object1 + motion and then combine the result with object2 + motion.
Because of Reflections and Refractions you may not get Transparency in the alpha channel, that's correct.
How to render the different layers/or passes is up to you, everything that works is OK (consider you may need both, semi transparent and full opaque/transparent mattes) .
dkrelina
in reply to: mspeer
Ok I see what you mean about it not being possible to have vectors moving in two opposite directions.
In this case, I would be comfortable with using full opaque/transparent mattes, as long as I get the silhouette of the plants (as seen in the image). Perhaps using a threshold, and then everything above or below is either 0% or 100%. Is this possible in the mv2DToxik pass? I have not been able to find how to do this. Or do I need to achieve it using additional mattes?
Technology Administrators
