- Mute
- Permalink
- Report
I've been trying to adapt the example code in the workspaceControl documentation into a class and haven't been able to do it. Here is the documentation code:
import maya.cmds as cmds def createCustomWorkspaceControlUI(*args): cmds.columnLayout() cmds.button() cmds.button() cmds.button() cmds.workspaceControl("myCustomWorkspaceControl", retain=False, floating=True, uiScript="createCustomWorkspaceControlUI()");
And here is a simplification of how I adapted it:
import maya.cmds as cmds class ui(object): def build(self): if cmds.workspaceControl("myCustomWorkspaceControl", exists=1): cmds.deleteUI("myCustomWorkspaceControl") self.wS = cmds.workspaceControl("myCustomWorkspaceControl", retain=False, floating=True, uiScript="createCustomWorkspaceControlUI"); def createCustomWorkspaceControlUI(self, *args): print("1") o = ui() o.build()
When I execute the previous code I get the following error:
# Error: line 1: NameError: file <maya console> line 1: name 'createCustomWorkspaceControlUI' is not defined #
On the other hand, if you execute inside of Maya
and then execute my adapted code it will work. The documentation and errors I've been getting tell me that uiScript only accepts two kinds of input: strings and functions. I believe that methods inside a class are not accepted by the uiScript as they are technically not the same as functions. Am I wrong? Is my only solution to turn the whole ui creation into a function not part of my UI class?
Thank you in advance
