& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
i try to extend our shading workflow with the possibility to use several uvSets. I want to add an attribute to the texture with a name like "expectedUvSet" with a value like "pattern". If the mesh have a uvSet with the name "pattern" i want to connect it.
To connect the UVchooser Node is pretty messy. Is there a easy way to do this? In the relationship editor it is pretty easy to connect texture and uvSet. So is it possible highjack some of that code? Or is another method outthere i am not aware of?
Cheers,
Manuel
Hi!
I think what you are looking for is the uvLink command.
Here's the python documentation:
https://download.autodesk.com/us/maya/2010help/CommandsPython/uvLink.html
I hope this helps!
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
