userSetup.py and script editor import same module/package twice
dominik6UUXE
dominik6UUXE
I have a singleton in a module I am importing in my userSetup.py.
# Package/Module.py
class Singleton:
    def get_instance(): ...
# userSetup.py:
from Package import Module
cls = Module.get_instance()
# In the script editor, I can use:
print(cls, Module)
# >>> (instance, module)
cls2 = Module.get_instance()
cls == cls2
# >>> False
I suspect this is because the globals() from the userSetup.py gets passed into the script editor env and sys.modules stays empty.
While I dont plan to run this in the script editor, there will be other packages and modules or even shelves run from within Maya that will import the Module and all try to get the instance of the singelton
Any suggestions how to accomplish this without trusting my peeps that they dont `import Module`? Or without misusing pythons import system or having to pass globals() to any subsequent tool?
dominik6UUXE
Wrapping it into a function and calling it through evalDeferred() seems to work. Not sure if that just works in this case or if it will generally work. "the next available idle time" is what the documentation says but I am not sure what that means specifically.
I havent tested it, but it might break if someone calls processIdleEvents(). Or not.. I dont know 🙂
BigRoy
Are you sure your singleton implementation actually stores the singleton instance correctly in the module?
