Untick display layer checkbox
Hi, I'm using a python script to turn the visibility off for some display layers, and it's working fine except the fact that the checkboxes for the layer looks like the visibility is still on. Is there a way to change these boxes?
olarn
The implementation looks like this.
global proc setDisplayLayerVisibility(string $layer, int $layerVisibility)
	setAttr ($layer + ".visibility") $layerVisibility;
	//Update layer button UI
	layerButton -edit -layerVisible $layerVisibility $layer;
Apparently this command were used to update the UI.
http://help.autodesk.com/cloudhelp/2018/ENU/Maya-Tech-Docs/CommandsPython/layerButton.html
