The problem of python using (if..else) and (optionMenu)
niuxihuanming
niuxihuanming
Hello, everyone, this is a code to rename and modify the shader UDIM. I have two questions now. The first question: I want to add one in set_name () If..else function, I want name_01=name_00 when textField doesn't have any input, otherwise execute rename_0. Now I've added if.else, but it doesn't seem to work, Second question, I want to modify uvTilingMode of shader file node through optionMenu now, but I don't know how to call the value of uvTilingMode with menuItem.If anyone knows please give pointers, thanks
def set_name():
        #tx
    rename_0 = cmds.textField("rename", q=True, text=True)
    br =cmds.optionMenu(symbol, query=True, value=True)
        # Attribute name
    typeall=['import','file']
    for i in cmds.ls(sl=1,dag=1,type='transform'):
                 #Get the object name
        name_00 = [k.split("Shape")[0] for k in cmds.ls(i)][0]
   #if.......else
        for a in rename_0:
            if rename_0==' ':
               a=name_00
        else:
               a=rename_0
        for i1 in typeall:
            try:
                node_type_all=get_node_type(i1,i)
                name_01 = a
                name_02=str(i1)
                name_04=br
                for i2 in node_type_all:
                    try:
                        name=name_01+ name_04 +name_02
                        set_node_name(i2,name,i)
                    except:
                        pass
            except:
                pass
def file_setup0():
    all_files = cmds.ls(type="file", sl=True)
    for n in all_files:
        STS = cmds.optionMenu(Tiling, query=True, value=True)
        cmds.setAttr('{0}.uvTilingMode' '{}'.format(n), STS)
cmds.window( title='maya_tool')
cmds.columnLayout()
#####################set_name(TheSuffix)
cmds.rowLayout(nc=5)
cmds.text("name:", h=30, w=30)
cmds.textField("rename",h=30,w=110, editable=True)
cmds.optionMenu("symbol", w = 155, h=30, label = "Add underline?:")
cmds.menuItem( label='')
cmds.menuItem( label='_')
cmds.button("sure", w=50, h=30,c="set_name()")
cmds.setParent( '..' )
#####    file_setup0()
Tiling=cmds.optionMenu("Tiling", w = 364, label = "UV Tiling Mode")
cmds.menuItem( label='off' )
cmds.menuItem( label='0-based' )
cmds.menuItem( label='1-based' )
cmds.menuItem( label='UDIM' )
cmds.menuItem( label='Tiles' )
file_setup0()
cmds.showWindow()
jmreinhart
I cleaned up your code and fixed what I think you were asking about, but your question is a bit unclear.
Some general advice:
  • Use more descriptive variable names. Stuff like name_00 and name_01 make it very hard to understand what your code is doing when reading it.
  • Please include your whole code or just a small section. You are calling functions that you did not include in the code you posted, which makes testing the whole code impossible.
  • Don't indent your comments.
  • Please add some comments before sharing your code so that it's easy for people to know what you want the code to do.
def set_name(*args):
    # Get the contents of the rename textfield
    rename_text = cmds.textField("rename", q=True, text=True)
    underline = cmds.optionMenu("symbol", query=True, value=True)
    # For each selected object
    # WHAT DO YOU WANT THIS cmds.ls TO RETURN?
    for each_transform in cmds.ls(sl=1,dag=1,type='transform'):
        # Get the name of the transform node the shape
        # USING NAMES INSTEAD OF NODE TYPES IS GENERALLY BAD
        transform_name = [k.split("Shape")[0] for k in cmds.ls(each_transform)][0]
        # If the rename_text is empty then keep the transform name
        result_name = ''
        if rename_text:
           result_name = transform_name
        else:
           result_name = rename_text
        for j in ['import','file']:
            # ONLY USE TRY AND EXCEPTS IF YOU REALLY NEED THEM
            try:
                final_name = result_name + br + str(j)
                # MISSING FUNCTION
                for k in get_node_type(j,each_transform):
                    try:
                        # MISSING FUNCTION
                        set_node_name(k,final_name,each_transform)
                    except:
                        pass
            except:
                pass
def file_setup0(STS):
    for n in cmds.ls(type="file", sl=True):
def create_window():
    # Create the window
    cmds.columnLayout()
    cmds.button("sure", w=50, h=30, c= set_name)
    tilingMenu =cmds.optionMenu("Tiling", w = 364, label = "UV Tiling Mode", changeCommand = file_setup0)
    cmds.showWindow()
create_window()
niuxihuanming
Thank you, the first problem is solved, and the second problem is that I want to use optionMenu to modify the UV Tiling Mode 812968b03c650097ec6faabf910ea4f.png
jmreinhart
Well this code is getting called when you change the optionMenu, right?
Do you get an error?
If not then the issue is probably this line
This will return the selected nodes that are of type "file". If the node is not selected it won't be affected.
This line also looks wrong.
It should be
cmds.setAttr('{}.uvTilingMode'.format(n), STS)
niuxihuanming
still error
# Error: RuntimeError: file <maya console> line 3: setAttr: Error reading data element number 1: 2 #
My code to execute a single value is
def file_setup():
    for n in all_files:
        cmds.setAttr('{0}.uvTilingMode'.format(n), 3)
Before I used button to control, but using button can only control one value, I want to control with optionMenu)
Command execution receipt
 setAttr "file1.uvTilingMode" 2
The current code
##STS is an int value
        cmds.setAttr('{}.uvTilingMode'.format(n),STS)
    cmds.optionMenu( w = 364, label = "UV Tiling Mode", changeCommand = file_setup0)
    cmds.menuItem( label='0-based(Zbrush)' )
    cmds.menuItem( label='1-based(Mudbox)' )
    cmds.menuItem( label='UDIM(Mari)' )
    cmds.menuItem( label='Explicit Tiles' )
jmreinhart
        stsInt = ['off','0-base','1-based','UDIM','Tiles'].index(STS)
        cmds.setAttr('{0}.uvTilingMode'.format(n), stsInt)
Try this as file_setup0.
niuxihuanming
thank you very much
