Syntax error - assigning UVs to alembic groom
3Dwindle
3Dwindle
Hi, I'm trying to assign root UVs to an alembic Maya XGen file, so that I can give the XGen fur the colours of the mesh underneath in Unreal Engine. I have a jaguar mesh with UVs assigned, and am trying to transfer them to the alembic groom. I'm using the Epic code, however I keep getting an "# Error: invalid syntax# " notification. I'm using Maya 2022. I'm not very experienced in programming, so I would hugely appreciate it if anyone is able to spot what is causing the code to crash. Thank you so much in advance!
Epic documentation: https://docs.unrealengine.com/4.27/en-US/WorkingWithContent/Hair/XgenGuidelines/
from maya import cmds
from maya import OpenMaya
import os
def create_root_uv_attribute(curves_group, mesh_node, uv_set='map1'):
Create "groom_root_uv" attribute on group of curves.
# check curves group
if not cmds.objExists(curves_group):
raise RuntimeError('Group not found: "{}"'.format(curves_group))
# get curves in group
curve_shapes = cmds.listRelatives(curves_group, shapes=True, noIntermediate=True)
curve_shapes = cmds.ls(curve_shapes, type='nurbsCurve')
if not curve_shapes:
raise RuntimeError('Invalid curves group. No nurbs-curves found in group.')
else:
print "found curves"
print curve_shapes
# get curve roots
points = list()
for curve_shape in curve_shapes:
point = cmds.pointPosition('{}.cv[0]'.format(curve_shape), world=True)
points.append(point)
# get uvs
values = list()
uvs = find_closest_uv_point(points, mesh_node, uv_set=uv_set)
for u, v in uvs:
values.append([u, v, 0])
#print (str(u) + " , " + str(v) )
# create attribute
name = 'groom_root_uv'
cmds.addAttr(curves_group, ln=name, dt='vectorArray')
cmds.addAttr(curves_group, ln='{}_AbcGeomScope'.format(name), dt='string')
cmds.addAttr(curves_group, ln='{}_AbcType'.format(name), dt='string')
cmds.setAttr('{}.{}'.format(curves_group, name), len(values), *values, type='vectorArray')
cmds.setAttr('{}.{}_AbcGeomScope'.format(curves_group, name), 'uni', type='string')
cmds.setAttr('{}.{}_AbcType'.format(curves_group, name), 'vector2', type='string')
return uvs
def find_closest_uv_point(points, mesh_node, uv_set='map1'):
Find mesh UV-coordinates at given points.
# check mesh
if not cmds.objExists(mesh_node):
raise RuntimeError('Node not found: "{}"'.format(mesh_node))
# check uv_set
uv_sets = cmds.polyUVSet(mesh_node, q=True, allUVSets=True)
if uv_set not in uv_sets:
raise RuntimeError('Invalid uv_set provided: "{}"'.format(uv_set))
# get mesh as dag-path
selection_list = OpenMaya.MSelectionList()
selection_list.add(mesh_node)
mesh_dagpath = OpenMaya.MDagPath()
selection_list.getDagPath(0, mesh_dagpath)
mesh_dagpath.extendToShape()
# get mesh function set
fn_mesh = OpenMaya.MFnMesh(mesh_dagpath)
uvs = list()
for i in range(len(points)):
script_util = OpenMaya.MScriptUtil()
script_util.createFromDouble(0.0, 0.0)
uv_point = script_util.asFloat2Ptr()
point = OpenMaya.MPoint(*points[i])
fn_mesh.getUVAtPoint(point, uv_point, OpenMaya.MSpace.kWorld, uv_set)
u = OpenMaya.MScriptUtil.getFloat2ArrayItem(uv_point, 0, 0)
v = OpenMaya.MScriptUtil.getFloat2ArrayItem(uv_point, 0, 1)
uvs.append((u, v))
return uvs
def abc_export(filepath, node=None, start_frame=1, end_frame=1, data_format='otawa', uv_write=True):
job_command = '-frameRange {} {} '.format(start_frame, end_frame)
job_command += '-dataFormat {} '.format(data_format)
job_command += '-attr groom_root_uv '
if uv_write:
job_command += '-uvWrite '
job_command += '-root {} '.format(node)
job_command += '-file {} '.format(filepath)
cmds.AbcExport(verbose=True, j=job_command)
def main():
export_directory = 'D:/Projects/Jaguar_Groom/Jag_Groom_copied_14_07/New/Maya_Xgen'
hair_file = os.path.join(export_directory, 'hair_export.abc')
curve_top_group= 'alembic_curves:jaguar_main_fur_splineDescription'
uv_mesh='retopo_furmesh'
create_root_uv_attribute( curve_top_group , uv_mesh)
abc_export(hair_file, curve_top_group)
main()
Kahylan
Hi!
When you get a synthax error, while you are using older python code in maya 2022+. It is always worth checking if the print statements are in brackets. Because Python 2.7 did not require that, but Python 3 does. This was also the problem here.
import os
    else:
        print ("found curves")
        print (curve_shapes)
    # get curve roots
    points = list()
    # get uvs
    values = list()
    for u, v in uvs:
    # create attribute
    return uvs
    # check mesh
    # check uv_set
    uvs = list()
        uvs.append((u, v))
    return uvs
    if uv_write:
def main():
    export_directory = 'D:/Dev/Ref'
    curve_top_group= 'description1|SplineGrp0'
    uv_mesh='pPlane1'
main()
I didn't have a groom example at hand to test it out. So it can be that this code will cause you further problems. But since you have it from epic, I think it should be ok.
I hope it helps!
3Dwindle
That's fantastic, thank you so much for your help - hugely appreciate it!
3Dwindle
That's fab, thank you so much for your help - hugely appreciate it!
qilong_han
Community Visitor
Community Visitor
Hero!
