Selection opposite.
Selection opposite.
dg3duy
Selection opposite.
dg3duy
Now I have a difficulty because I have 2 codes that work separately, how is it possible to unite them and make only 1?
One code works to select the parts that deform the legs and arms and another code works only selecting the platforms of the feet and hands.
And the additional difficulty is that it only works with 1 object selected and not with multiple selections.
Selecting the platforms of the feet and hands.
In this form are the names of the elements to be selected.
ctrl_arm_ik_L
ctrl_arm_ik_R
ctrl_leg_ik_L
ctrl_leg_ik_R
global proc rsMirrorSelect()
    string $rsSl[];
    $rsSl = `ls -sl`;
    int $numTokens;
    string $rsTemp[];
    $numTokens = `tokenize $rsSl[0]"_" $rsTemp`;
    if($rsTemp[$numTokens-1]=="L")
        select -r ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_R");
    else
        select -r ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_L");
rsMirrorSelect;
Select the parts that deform the legs and arms
ctrl_leg_bd_L_1
ctrl_leg_bd_L_2
ctrl_leg_bd_L_3
ctrl_arm_bd_L_1
ctrl_arm_bd_L_2
ctrl_arm_bd_L_3
    string $rsSl[];
    $rsSl = `ls -sl`;
    int $numTokens;
    string $rsTemp[];
    if($rsTemp[$numTokens-2]=="L")
        select -r ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_R"+"_"+$rsTemp[4]);
    else
        select -r ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_L"+"_"+$rsTemp[4]);
rsMirrorSelect;
Original question.
https://forums.autodesk.com/t5/maya-programming/quick-script-to-switch-control-selection-to-the-oppo...
Kahylan
Hi!
I wouldn't rely on stringformating this much, there are probably more elegant/universal ways to solve this problem.
But since you asked for it, this is how you combine your two scripts:
    string $rsSl[];
    $rsSl = `ls -sl`;
    int $numTokens;
    string $rsTemp[];
    else if ($rsTemp[$numTokens-1]=="R")
    else if ($rsTemp[$numTokens-2]=="L"){
    else if ($rsTemp[$numTokens-2]=="R"){
rsMirrorSelect;
This also has the advantage that if some other object is selected, it won't do anything instead of throwing an error because there is no object with the same name but an L in the last place.
I hope it helps!
dg3duy
@Kahylan The answer is exactly what I was looking for, thank you very much.!
I just wonder if it is possible to make a version that supports multiple selected objects.
Kahylan
As always, just add a for-loop to go through your selection and replace the variable that took out the first selected object with the loop variable.
Then all you need to do is change the selection mode from replace to add and clear your selection before you start the loop.
    string $rsSl[];
    $rsSl = `ls -sl`;
    select -cl;
    for ($rs in $rsSl){
        print($rs);
        int $numTokens;
        string $rsTemp[];
        $numTokens = `tokenize $rs "_" $rsTemp`;
            select -add ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_R");
            select -add ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_L");
            select -add ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_R"+"_"+$rsTemp[4]);
            select -add ($rsTemp[-0]+"_"+$rsTemp[1]+"_"+$rsTemp[2]+"_L"+"_"+$rsTemp[4]);
rsMirrorSelect;
dg3duy
Believe me what you did is epic!
if I could give you more than 1 point I would give you without hesitation! Thank you very much for providing your knowledge.
