Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Select faces inside volume
2 REPLIES 2
magillaGuerilla
234 Views, 2 Replies
I need to select the faces of one mesh that are contained within the volume of a primitive (cube or sphere) and write those faces to a set. I would like to avoid having to learn Bifrost just for this simple task, but open to all suggestions.
regards,
Cam.
2 REPLIES 2
If you don't have access to Bifrost, one way to solve this problem is by using MASH. MASH is a Maya plugin that allows you to generate complex motion graphics quickly. To select the faces inside a volume, you can create a MASH Distribute node and place a cube or sphere inside the volume. Then, set the MASH Distribute node to select the faces inside the volume. Finally, write those faces to a set. This should give you the desired result.
Thanks Alishah,
I appreciate the suggestion but since this is for plugging into a Yeti system I would also like to avoid MASH as well as Bifrost. This is not a complex problem, it should be achievable with mel or python. Max has a modifier that does it, Unity and Unreal can do it at 160fps, unsure why Maya doesn't have a built in solution.
